YY3010966 Posted January 15, 2014 Share Posted January 15, 2014 hi, everyone . im a new houdiner,there is a question need help i wanna create a custom force always point to surface normal,like a deformed graivity,it could pull particle back like common gravity,the difference is the different ground position has different gravity dirction ,not always point to -Y direction.it should work just like real earth. i attach an image ,the red arrow mean the direction of gravity,and balck circle mean object surace.sorry for my ugly drawing. any help will be appreciate. Quote Link to comment Share on other sites More sharing options...
ikarus Posted January 15, 2014 Share Posted January 15, 2014 If you attach sdf volume data to a field force dop it will create a force with the direction of the gradient of the sdf. Quote Link to comment Share on other sites More sharing options...
narbuckl Posted January 16, 2014 Share Posted January 16, 2014 Yeah, exactly what Ray said, create an SDF volume of your surface, get the volume gradient, normalize it, add to velocity. HAI RAY! xD 1 Quote Link to comment Share on other sites More sharing options...
YY3010966 Posted January 16, 2014 Author Share Posted January 16, 2014 @ikarus,@narbuckl: thanks guys for u suggestion,bcoz im total new to hoduini,i understand the idea u said,but dont know how make it done.sdf mean isoffset SOP?gradient of sdf mean wt? sorry for my idiot could u attach a simple example hip? thanks Quote Link to comment Share on other sites More sharing options...
YY3010966 Posted January 16, 2014 Author Share Posted January 16, 2014 attach file is wt i did ,but pretty far away i want. test.hipFetching info... Quote Link to comment Share on other sites More sharing options...
narbuckl Posted January 17, 2014 Share Posted January 17, 2014 Here is an example of a deforming animated shape where I used the SDF as the force in the particle simulation. Hope this helps sdfForce_example.hipFetching info... Quote Link to comment Share on other sites More sharing options...
YY3010966 Posted January 20, 2014 Author Share Posted January 20, 2014 On 1/17/2014 at 1:28 AM, narbuckl said: Here is an example of a deforming animated shape where I used the SDF as the force in the particle simulation. Hope this helps thank u so much,narbuckl, u r so kind . but the hip didnt work for me . no particle appea and throw error at pop solver . u use ver13 ? my version is 12.5.could u explain how it work? anyway,thanks Quote Link to comment Share on other sites More sharing options...
