Motion blur VDB volume
RogerW
Hey Guys,
I am trying to render out a VDB volume with motion blur and I cant seem to get it right  :blink: .
All my geo is rendering out correctly with motion blur but not the volumes.
What is the correct set up for rendering out VDB volumes with motion blur ?
Many Thanks
[sOLVED]
For those who are interested or have the same problem,
You need to add an attribute on the VDB from polygon node called  ( point.v ) give it a name of ( vel ) and change the vector type to ( Displacement/Velocity/Acceleration ).
ps. and make sure that your motion blur is turned on on the geo node and in your rop.
Hey Guys,
Many Thanks
  • 2 months later...
I am running into a similar issue. I have a set of points from a flip simulation. These points have a "v" attribute and I have also added a "vel" attribute with the same values. When I use the volume rasterize points SOP I cannot seem to get motion blur to work. I have motion blur enabled on the geo and on the ROP as well. Any hints as to what else I might be missing to get motion blur to work?
