Hi guys, I have spent the past few weeks watching some tutorials getting to learn Houdini. Right now I'm playing around with pyro FX. I am trying to get a fire ball explosion type of result, like this :
;where the heat cools off and produces smoke.
But here the flame or heat just constantly rises, I've been tweaking the values for quite a while now but cant seem to get the heat to die down; heat cutoff doesn't seem to change much.
Could you guys help me out on this please?
Thanks
pyro_v01_01.hip
Edited by beeper000
Tweak the cooling rate parameter in your solver, which basically specifies how fast the fluid temperature cools down to zero.
Also play with temperature diffusion... Higher values of cooling rate and lower values of temperature diffusion approximate your reference.
Cheers
Edited by rafaelfs
Cheers
Thanks for the reply Rafael, it did help to some degree but I'm still seeing a lot of the heat in the simulation.
