Naming Objects within DOPs?
synthure
I'm trying to change the name of an object within a DOP during the simulation. specifically when a piece breaks from its glue structure. Problem is, the Modify Data can't seem to access the level of data the "Name" is located under. Do you know of a way that i can change the name data while in the DOP?
I've attached an image of the data that i'm trying to manipulate.
Thanks
post-9415-0-89635100-1394151177_thumb.pn
  • 3 weeks later...
