Hqueue
Hi everyone
I try to set up a render farm at the moment only with  one computer to test if i can make one computer the server and the client at the same time ( if i understand well it's possible..).
I install houdini and set up the shared folder and the server ... the installation was fine i can enter in the web interface without problem but the problem starts when i try to add the client.  I fill out the form but always the message  says that.
any one can pointing me in the correct direction or tell me what i do wrong
Thanks!!!!
Hi everyone
I resolved the first problem ... It was a problem in syntax but now i get this in the web....
Always stay in red and to put in orange i must to upgrade all the time.. and other hand cpus, memory, and disk space its not displayed.
I search in the files where the client its created and I found  this fault.
windows.py point to windows helper functions
linuxs.py point to linuxs but macosx.py point to linux.
in the case that this is the problem??? How can i fix that.... i try to reinstall many times but always make the same ... and I'm a little bit lost.
Any help is appreciated
post-7130-0-94152100-1395346262_thumb.pn
post-7130-0-66640700-1395346845_thumb.pn
