Thin Fluid Flip - Reducing PartSep makes it worse?!
dpap
Why when I reduce  Particle Separation looks worse than iot did when it was higher?
Adding resolution to the sim by reducing part. separation shouldn't just give more details to my fluid?
Why is it reducing the amount of surface that is being coverd by the fluid?
At the right side of the fluid almost half of the surface is not covered as it was when part.sep was 0.01
How can I have the whole surface covered and have enough resolution/detail at the same time? Am I doing something wrong?
Thanks!
