gas build collision mask
hello !
i want to know about gas build collision mask node
i already knew that created collision, vel, index field where affector objects overlap with the fluid field
my hip file is being unoverlap anything
and box set to affector object
but hip file is ignore affector object overlaping with the fluid field also create collision field(SDF) by fullsize
i guess i don't understand it or error?
collisionmask.hipnc
Edited by sonppw
i can solve problem
turn on invert iso in scalar field visualization
but why i should turn on it?
accroding help file
collision field created by
Each voxel of this field is the distance to the closest affector object. If it is inside an affector object, it is the negative distance to the surface.
so in my head is affector object inside value is negative that represent SDF
why i should turn on invert iso??
