Caerus7 Posted April 11, 2014 Share Posted April 11, 2014 Hi All, I finally managed to get python to create points and faces, but I'm trying to figure a few things out. From the documentation I've gathered that I can view and find edges, but I can't set them. I can partially control edge generation with vertex order, but not much it seems. Is there a way to create / delete / control edge connections with Python? In my example I used python to read the points from a second grid and create them inside the first. (First attempt it connected them by point order.) What I'd like to be able to do is add all the points, then recreate the edge structure to be identical to input. Which is possible, but involves a lot more code than a single iteration through edge connections and a second command to attach them. I've attached a simple file I made to test creating polygons in code. Thanks py_tests.hipnc Quote Link to comment Share on other sites More sharing options...
