Reading voxel by index in DOPs?
PatW
I am trying to do a simulation in DOP using fields.
In Gas Field Vop, is there a way to read data from another voxel by index?
In Vop Sop there is a node called Volume Index that do this kind of thing but I can't get it works in Gas Field Vop.
Thanks
Hi PatW,
I think you can just set a dop field as one of the vop inputs using the op: expression. From the help:
You can now use the op: path syntax to refer to DOP data. For example op:/obj/AutoDopNetwork:0/Geometry references the Geometry data in the first DOP object in the AutoDopNetwork object. The second : (colon) character separates the node path from the DOP data path.
Hope this is what you were looking for,
~Ilan
