harima Posted May 4, 2014 Share Posted May 4, 2014 Hi All What I want to do is to volume sample a surface SDF with a popvop connected in the second input of a flip solver. This surface SDF is basically a previous flipsim I run. So basically I want to have the new flip sim rest on top of the surface of the old sim. However I try to bring it I fail . This is what I tried so far. Isolate the surface volume in SOPS Then connect it to the second input of the dopnet and try to bring it as second context Geometry of the Popvop or as a Sop Path. It doesnt work Second approach was to create a SopScalarField under the FlipObject and try to bind this new field in a parameter. It doesnt work either. I am sure its doable but I must be missing something with the syntax. I also tried to bring the surface as a collision with a source volume DOP. and although it seems to create a collision for me ( checking with the visualitation tab) it looks it need many substeps to work ) Thanks in advance Quote Link to comment Share on other sites More sharing options...
