Arthur~Chiu Posted May 19, 2014 Share Posted May 19, 2014 i want to set Multi-Parms attribute list menu, single attribute list menu i have been set right below is code define funsion: static void buildAttrMenu(void *data, PRM_Name *theMenu, int theMaxSize, const PRM_SpareData *, PRM_Parm *) { SOP_Node *sop = CAST_SOPNODE((OP_Node *)data); if( sop ) { OP_Context context(0); const GU_Detail *gdp =sop->getCookedGeo(context); GA_AttributeFilter attrib_filter(GA_AttributeFilter::selectAll()); GA_AttributeFilter except_filter(GA_ATTRIB_FILTER_OR,GA_AttributeFilter::selectByName("filename"),GA_AttributeFilter::selectByName("P")); except_filter = except_filter.selectOr(except_filter,GA_AttributeFilter::selectByName("maxbounds"),0); except_filter = except_filter.selectOr(except_filter,GA_AttributeFilter::selectByName("pmatrix"),0); except_filter = except_filter.selectOr(except_filter,GA_AttributeFilter::selectByName("minbounds"),0); attrib_filter = attrib_filter.selectNot(except_filter,0); unsigned int i =0 ; for (GA_AttributeDict::iterator it =gdp->getAttributeDict(GA_ATTRIB_POINT).begin(GA_SCOPE_PUBLIC); !it.atEnd() && i<theMaxSize;++it) { const GA_Attribute *attrib = it.attrib(); if (attrib_filter.match(attrib)) { theMenu.setToken( attrib->getName() ); theMenu.setLabel( attrib->getName() ); i++; } } theMenu.setToken(0); theMenu.setLabel(0); } else { theMenu[0].setToken(0); theMenu[0].setLabel(0); } } define parms: static PRM_Name names[] = { PRM_Name("attrib","Attribute Name"), PRM_Name() }; static PRM_ChoiceList theFloatAttribMenu((PRM_ChoiceListType)( PRM_CHOICELIST_TOGGLE|PRM_CHOICELIST_WILD|PRM_CHOICELIST_REPLACE),(PRM_ChoiceGenFunc)buildAttrMenu); static PRM_Template theAttribTemplates[] = { PRM_Template(PRM_STRING,1,&names[0],&attributeDefault,&theFloatAttribMenu), PRM_Template() }; it work well but when i change the parm to Multi-Parms, code is : static PRM_Name names[] = { PRM_Name("attrib#","Attribute Name"), PRM_Name() }; it will popup error when create node in houdini,why and how to set Multi-Parms versions Quote Link to comment Share on other sites More sharing options...
