csp Posted May 29, 2014 Share Posted May 29, 2014 In H13 I am facing a problem frequently where I am adding parameters in a Digital Asset or an existing node and cant move it in a different position. I can't even create it in the first place by drag and drop, I have to use the arrows. I have no idea what is causing this. I though it was the two monitors because sometime by moving the 'Edit Operator Type Properties' window to the other monitor I was able to move the parameters. But now, nothing works. It's random because sometimes works, other times it doesn't. Any explanation? Quote Link to comment Share on other sites More sharing options...
csp Posted May 29, 2014 Author Share Posted May 29, 2014 never mind, it has to do with Houdini's windows in linux probably. When I enabled Always on Top, works. Quote Link to comment Share on other sites More sharing options...
