setting an environment variable via external hython
ch3
I am putting together a python script to render multiple files sequentially on a windows machine via cygwin. A rather big pain as I had to resolve all the path madness (\ vs /)... but it's almost there...
For some strange reason $HIPNAME on the output path of the rop node, evaluates to the full path and not just the file name. So whenever I use it on my output path (...project/renders/$HIPNAME:r/$HIPNAME:r.$F4.exr), it resolves to a non existing long path (...project/renders/...project\renders/...project\renders.$F4.exr) and fails
When I render my scene from the terminal via hscript it works fine. I wouldn't be surprised if it's another confusion caused by cygwin. But I was wondering if it's possible to change the content of a variable via python, in the same way you can do via the Alias & Variables UI. I just want to test whether it will work if I set it my self to the filename, prior to executing the render.
thanks
Hey!  Yeah, you can do that, although I'm not sure of the python specific version.  When I've been wanting to change a global variable in some code evaluated by hython or hscript, I just use this:
set -g name = value
I don't know that there's a hython equivalent, but this will let you do it in hython as a workaround:
hou.hscript('set -g name = value')
Does anyone else have a better way to do that?
thanks
Although, according to the help files you could use setenv, too.
setenv name = value
hou.hscript('setenv name = value')
set -g name = value
Cool, thanks a lot Dee
I managed to make it work.
I now have a .bat icon on my desktop that runs cygwin and a shell batch file for multiple sequential renders. Each render command is a python script that does various checks and runs a hython script to do the actual render. Between all theses, I had to wrangle the madness between unix/win paths, slashes, backslashes, double backslashes, quadruple backslashes, global variables and more! :wacko:
I think I now need a beer!
Why not run it through a process or something?  Set up your paths so they are similar on both...  I'm just doing this off the top of my head and I'm still learning python, but wouldn't it be something like this:
path = 'path/to/information'
def makePath(path):
  basepathwin = 'C:\\'
  basepathlin = '/media/storage/houdini/data/'
  import platform
  platform = platform.system()
  finalpath = ''
  if platform == 'Linux':
    finalpath = basepathlin + path
  else:
    pathsplit = path.split('/')
    finalpath = pathwin
    foreach item pathsplit:
      finalpath = finalpath + item + '\'
  return finalpath
print makePath(path)
Would that not allow you to store your paths in the unix standard but, if you were on windows, convert them to the proper paths depending?  That does sound like a lot of hassle, though.   :(
Edited by Dee
cygwin provides a command to do that and turn a path from windows to unix and vice versa. But even with that it was a bit of a pain, as passing windows line paths as arguments and variables, require to double the backslashes before hand, so they are not considered as escape characters.
It's all done now... I may just need to re-work the retry logic for certain cases.
Actually while on the topic... do you know of a way to tell if an exr is incomplete? Right now I am just checking with the file size, but it's hard to decide on an accurate threshold, as an incomplete exr still has partial data in it.
Awesome!  I didn't know that.  Where is that?  It sounds like a useful function.
I just noticed there is iinfo which comes with houdini and check the integrity of an image file!
I think this will do the job!
$ iinfo
Usage: iinfo [-i] [-s] picfile [picfile*]
Gives information about picture files
        -i       check file integrity
        -s       supress output
        -b       print out basic information only
