shinyary2 Posted June 25, 2014 Share Posted June 25, 2014 H13 POPs noob question! Is there a way to create custom attributes in POPs in H13 without using vexpressions or a sop solver? It seems that Add Attribute does not exist in the POP VOP, and there is no "POP Attribute" node that would replace the one I'm used to in H12 POPs. I realize it's relatively straightforward to create custom attributes using the wrangle node, but I would like to know if it's still possible without it, or if SideFX took that out. Quote Link to comment Share on other sites More sharing options...
ophamletsen Posted June 25, 2014 Share Posted June 25, 2014 You can use "Bind Export" inside the POP VOP Quote Link to comment Share on other sites More sharing options...
