olajay Posted July 16, 2014 Share Posted July 16, 2014 Hi guys, From time to time the wireframe turns grey when I'm working, and I have no idea why it does that. Theres no wireframe color option in the viewport options as well, that I know of. O. Quote Link to comment Share on other sites More sharing options...
olajay Posted July 16, 2014 Author Share Posted July 16, 2014 Okay, I found out you can set wireframe color locally on each object, but how do I set the global color, and why does it sometime change from dark grey to light grey? :s Quote Link to comment Share on other sites More sharing options...
Guest tar Posted July 16, 2014 Share Posted July 16, 2014 There was a bug on OsX with CopySop previously that would grey out wireframes - try the latest build The global wireframe colour is set in the 3DSceneColors.bw/wb file. Look for the 'WireframeColor: ' line File found here on OsX: /Library/Frameworks/Houdini.framework/Versions/13.0.401/Resources/houdini/config Once you modify it put it into your preferences in the config folder. It is then available in the the Display Options/Background Color Scheme pulldown Quote Link to comment Share on other sites More sharing options...
