Sort by position?
I have a question, I have an image, which has a center, and extended out like a few curves that comes from a same center point. How should I sort it so the point at center is largest number, and the furtherst is 0? I guess it should be done in vopsop or sort node expression.
Hey,
You can use a sort sop and sort the points by proximity to point and then set the reverse toggle on the node. This will order your points on a "first match basis". Depending on what you want to achieve it may be better to use an attribute instead of a point number.
