argilop Posted July 23, 2014 Share Posted July 23, 2014 Hi, I am developing a simple effect using a Pop Attract which attracts pieces of a fractured packed object into a goal position. I am having problems in controlling this effect with a controller which specifies the area when the effect should start. I have an attribute called "camp" which recognizes when the object is in the boundary of the controller, but once inside DOPs this attribute has no effect. I tried calling the attribute with point and prim expression but still not working. USING_POP_FORCES_test.hipnc Quote Link to comment Share on other sites More sharing options...
