venator11387 Posted August 25, 2014 Share Posted August 25, 2014 I'm learning Python in Houdini and I'm just writing up a simple code. Everytime I try to use the .createOutputNode() I keep getting an `invalid node name` error. The operator name of the node I'm trying to create entering is definitely correct as I've checked using the Type Properties, so I'm not sure what's causing this. The attempted operation failed. invalid node name Traceback (most recent call last): File "voronoi_set_up", line 16, in <module> File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.509/houdini/python2.7libs\houpythonportion.py", line 220, in createOutputNode exact_type_name) File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.509/houdini/python2.7libs\hou.py", line 22595, in createNode return _hou.Node_createNode(*args, **kwargs) OperationFailed: The attempted operation failed. Invalid node name import toolutils # If there is a node selected, then execute the code if hou.selectedNodes(): # Set the selected node to be the source node source_node = hou.selectedNodes()[0] # Create the Null SOP output for the source geo start_node = toolutils.genericTool(kwargs, 'null', 'OUT_GEO') start_node.setInput(0, source_node) start_node.setPosition(source_node.position()) start_node.move([0, -1]) start_node.setColor(hou.Color([0, 0, 0])) # Create a VDB From Polygons node to turn the source geo into a fog volume geometry fog_node = start_node.createOutputNode('vdbfrompolygons', 'create fog volume') Quote Link to comment Share on other sites More sharing options...
graham Posted August 25, 2014 Share Posted August 25, 2014 You are trying to create a node whose name has spaces in it, "create fog volume", which isn't allowed in Houdini. You need to use underscores: "create_fog_volume". Quote Link to comment Share on other sites More sharing options...
venator11387 Posted August 25, 2014 Author Share Posted August 25, 2014 I knew it had to be a noob mistake like that Thank you! Quote Link to comment Share on other sites More sharing options...
