borisb2 Posted September 10, 2014 Share Posted September 10, 2014 Hi, .. doing some pipeline work at the moment. I'm struggeling to connect the input of a created node to the global node. This all works fine: VOPLength = VOPNode.createNode('length','length_' + rnodeUpName) VOPFit = VOPNode.createNode('fit', 'fit_' + rnodeUpName) VOPFit.setInput(0,VOPLength) So far, so good. But this: VOPLength.setInput(0,'global1',2) doesnt work at all, no matter what I set there. I can't get my created nodes connected to the global node. What would be the propper way for connecting in VOP? .. same I will need later for connecting to 'output1' I guess Thanks Quote Link to comment Share on other sites More sharing options...
borisb2 Posted September 10, 2014 Author Share Posted September 10, 2014 sorted! if anybody is interested: # VOP SOP ------------------------------------------- # --------------------------------------------------- VOPNode = rnodeUp.createNode('vopsop','vel_' + rnodeUpName) VOPNode.setFirstInput(switchNode) newPosX = pos[0] + 4.5 newPosY = pos[1] - 4 VOPNode.setPosition([newPosX,newPosY]) VOPGlobals = VOPNode.node('global1') VOPLength = VOPNode.createNode('length','length_' + rnodeUpName) VOPLength.setInput(0,VOPGlobals,2) VOPFit = VOPNode.createNode('fit', 'fit_' + rnodeUpName) VOPFit.setInput(0,VOPLength) srcMin = VOPNode.createNode('parameter', 'velMin') srcMin.parm('parmname').set('$OS') srcMin.parm('parmlabel').set('$OS') VOPFit.setInput(1,srcMin) srcMax = VOPNode.createNode('parameter', 'velMax') srcMax.parm('parmname').set('$OS') srcMax.parm('parmlabel').set('$OS') srcMax.parm('floatdef').set(10) VOPFit.setInput(2,srcMax) rampNode = VOPNode.createNode('rampparm', 'velRamp') rampNode.parm('parmname').set('$OS') rampNode.parm('parmlabel').set('$OS') rampNode.setInput(0,VOPFit) #VOPNode.parm('velRamp1cr').set(0) #VOPNode.parm('velRamp1cg').set(.3) #VOPNode.parm('velRamp1cb').set(1) VOPOutput = VOPNode.node('output1') VOPOutput.setInput(8,rampNode) # --------------------------------------------------- # --------------------------------------------------- Quote Link to comment Share on other sites More sharing options...
