csp Posted September 12, 2014 Share Posted September 12, 2014 Hi, I have two questions regarding procedural created volumes using Vex Volume Procedural. 1. Is it possible to override material parameter per object on the Object level, the same you can do with the material node in the SOP level? 2. Vex Volume Procedural creates only one density volume. Is it possible to have more volumes created like Cr,Ce,Vel? Thanks, Christos Quote Link to comment Share on other sites More sharing options...
