Config Questions
harima
edit>autosave checkbox to turn it on, you can adjust preferences for it in the edit>preferences>save options dialog
hscript command to turn it on and off is just 'autosave on|off'
for your temp folder you just need to set the environment variable 'HOUDINI_TEMP_DIR' to whatever you want it to be
-Nathan
Thank you!
Is there a way to have the auto save on as default? Maybe with another env variable?
Right now I have to remember and turn it on for every session.
About the temp. What does this folder full up with? I was working on a shot with many Sim stuff and checking every now and then how big the temp folder is. It was always so small -around 80mb- is that normal?
Cheers!
Edited by harima
the temp folder will fill up with sim cache with 'Allow Caching To Disk' on AutoDopNet node - if you are rendering out your file then it would simple write it to the $Hip/cache etc
