Advec cloth by flip motion (Flip/Cloth interaction)
Hello guys!
Im trying to make a cloth react to flip fluid on a beach(the cloth is on ground)...making cloth sim be afected by fluid motion as forces.
the cloth (FEM) and flipsolver are on same DOP.
i turn FEEDBACK to 1 on flipsolver, but not working. (its not easy like RBD right?)
Any ideas?
Thanks in advance!
Oh.. there's another problem, the fluidforce worked cloth reacts to fluid motion, but now i cant use the cloth as collider on fluid...
is FEM working with flip?
even if i use a trick... i re-import cloth from other SOP (with obj merge from simulated) as a collider, if i check "use deforming geo" the object deforms with "double" deformations like crazy... and if i check "ignore merge relationships"not deforms, but it not collide anymore... :/
may i missing something here?
