nicholas_yue Posted October 27, 2014 Share Posted October 27, 2014 Hi, When generating lots of geometries e.g. hair, fur, particles, grass etc, I am currently doing something like this gdp = allocateGeometry(); // Build all the geometry in gdp // Create a geometry object in mantra openGeometryObject(); // Add the geometry addGeometry(gdp, 0); closeObject(); However, I see that there is only one bounding box via getBoundingBox() Should I leave it to Mantra's optimization to deal with the billions of geometry or should I help by splitting them up into chunks and have bounding box for each "chunk" so as to keep Mantra's memory footprint in check. If taking the multiple bounding box approach, would I be looking at recursive procedural ? In any case, with multiple bounding box, is there any example I can have a look at ? Cheers Quote Link to comment Share on other sites More sharing options...
graham Posted October 27, 2014 Share Posted October 27, 2014 If you are only doing a single procedural then you can really only give Mantra a single bounding box for your entire geometry. If you want to be able to do the multiple bounding boxes based on some pre-defined groups or patches then yes, you'll need to build your procedural either recursively or using a different child procedural. For procedurals that do generate lots of geometry from well defined areas it is generally best to use this approach. Quote Link to comment Share on other sites More sharing options...
nicholas_yue Posted October 27, 2014 Author Share Posted October 27, 2014 If you are only doing a single procedural then you can really only give Mantra a single bounding box for your entire geometry. If you want to be able to do the multiple bounding boxes based on some pre-defined groups or patches then yes, you'll need to build your procedural either recursively or using a different child procedural. For procedurals that do generate lots of geometry from well defined areas it is generally best to use this approach. Thanks Graham, this will dove tail nicely with LOD too. Cheers Quote Link to comment Share on other sites More sharing options...
nicholas_yue Posted October 27, 2014 Author Share Posted October 27, 2014 If you are only doing a single procedural then you can really only give Mantra a single bounding box for your entire geometry. If you want to be able to do the multiple bounding boxes based on some pre-defined groups or patches then yes, you'll need to build your procedural either recursively or using a different child procedural. For procedurals that do generate lots of geometry from well defined areas it is generally best to use this approach. Hi Graham, Where can I find example of recursive procedural and child procedural ? Cheers Quote Link to comment Share on other sites More sharing options...
nicholas_yue Posted October 27, 2014 Author Share Posted October 27, 2014 Just found it....DemoMountain Quote Link to comment Share on other sites More sharing options...
