Querying point at a given UV location ?
  Given a GU_Detail which has a mesh with UV, is there in-build API to query a point position at an arbitrary UV location [assuming the input UV is within the UV range of the mesh] ?
Cheers
Hi. You need a GEO_Primitive::evaluateInteriorPoint() method, you can't just evaluate attribute on GU_Detail at given uv, without primitive.
