Guest mantragora Posted November 22, 2014 Share Posted November 22, 2014 (edited) ... is there some deeper story behind this? GUI_PolySoupBox(const GR_RenderInfo *info, const char *cache_name, const GEO_Primitive *prim); and then GUI_PolySoupBox::GUI_PolySoupBox(const GR_RenderInfo *info, const char *cache_name, const GEO_Primitive *prim) : GR_Primitive(info, cache_name, GA_PrimCompat::TypeMask(0)) ?Still not ticking? Lets continue GR_Primitive constructor takes (const GR_RenderInfo* info, const char* cachename, GEO_PrimTypeCompat::TypeMask primitivetype) GUI_PolySoupBox last argument is const GEO_Primitive *prim and we are setting GR_Primitive last argument as GA_PrimCompat::TypeMask(0) I don't see const GEO_Primitive *prim being used anywhere, but I could miss something, so what's the point?Maybe the point of this is to make something like return new GUI_PolySoupBox(info, cache_name, GA_PrimCompat::TypeMask(prim->getTypeId().get())); instead of return new GUI_PolySoupBox(info, cache_name, prim); ?Every GUI example in HDK docs have this. Thanks! BTW: What is this GA_PrimCompat::TypeMask? Is there some enum anywhere with values for this that I can use? BTW2: Looking at GUI_PolySoupBoxHook::createPrimitive(), there is a check for type of the GEO primitive, then we create new GUI_PolySoupBox() so it would be logical to set GA_PrimCompat::TypeMask instead of passing const GEO_Primitive. Edited November 23, 2014 by mantragora Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted November 23, 2014 Share Posted November 23, 2014 In other words: Do I have to pass const GEO_Primitive *prim in constructor of my custom GR_Primitive? GR_Primitive itself doesn't require it so why I would like to do that in my custom GR_Primitive? To accomplish what? Quote Link to comment Share on other sites More sharing options...
Syrux Posted November 27, 2014 Share Posted November 27, 2014 What I found: GA_PrimCompat::TypeMask(0) is to primitives as GA_PointGroup is to points TypeMask(0) filters primitives which match the type mask specified. When you selected (0), Houdini takes all the primitives. It is not necessary, that's way you can omit the argument, it works in the same way when you don't define point groups (check that zero) in gdp->getPointBBox(&bbox, 0); and Houdini takes all the points. "GA_PrimCompat::TypeMask(0)" can also be used as mask to iterate the defined groups of primitives in iterators, check this http://www.sidefx.com/docs/hdk13.0/_g_a___g_b_macros_8h.html#accfa36a011faa15dad3800e6ce2320eb Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted November 27, 2014 Share Posted November 27, 2014 What I found: GA_PrimCompat::TypeMask(0) is to primitives as GA_PointGroup is to points TypeMask(0) filters primitives which match the type mask specified. When you selected (0), Houdini takes all the primitives. It is not necessary, that's way you can omit the argument, it works in the same way when you don't define point groups (check that zero) in gdp->getPointBBox(&bbox, 0); and Houdini takes all the points. "GA_PrimCompat::TypeMask(0)" can also be used as mask to iterate the defined groups of primitives in iterators, check this http://www.sidefx.com/docs/hdk13.0/_g_a___g_b_macros_8h.html#accfa36a011faa15dad3800e6ce2320eb That's why I asked, maybe there should be GA_PrimCompat::TypeMask(prim->getTypeId().get()) and that's why we would like to pass const GEO_Primitive *prim in in custom GR_Primitive. Quote Link to comment Share on other sites More sharing options...
