Some problem at Houdini
yuantay
I had the same issue. Have you changed your temp directory to another drive which now doesn't exist?? or changed the name of the drive?? In that case, Houdini looks for temp directory which is not there. Hence it crashes. Check if you have this case.
My problem got solved after fixing this.
Edited by Swapniel16
It's a good idea (in general) to change the temp/TMP dirs and keeping them clean, meaning deleting stuff there on a regular basis :}
I used to have that issue with both Maya and Hou. It's gone now.
http://answers.microsoft.com/en-us/windows/forum/windows_7-files/change-location-of-temp-files-folder-to-another/19f13330-dde1-404c-aa27-a76c0b450818
