pointattribtype
csp
Is just me or pointattribtype script expression isn't working? No matter the type of the attribute is reading (integer, float, string) returns 1 which is means for float. Even when the attribute is invalid will return 1 instead of -1. Only when the path to surface node is invalid it will then return -1.
