nicholas_yue Posted December 12, 2014 Share Posted December 12, 2014 Hi, I am studying the tetprim example code. I see the following code and would like to find out if the returned GL buffer always expect one to fill them in with triangles ? Therefore if we have quads, we need to split it up into two triangles per quads ? If I have misunderstood the GL buffer returned by pos->map() and that it supports n-gon, where should one specify the per-polygon vertex count ? I have had a look at the GT code and it has the concept of vertex_order[] so I am fine with that. I want to test out a GR implementation hence the above question. ============= CODE ======================= // Initialize the number of points in the geometry. myGeo->setNumPoints( 12 * num_tets); // Fetch P (point position). If its cache version matches, no upload is // required. pos = myGeo->findCachedAttribOrArray(r, posname, RE_GPU_FLOAT32, 3, RE_ARRAY_POINT, true); if(pos->getCacheVersion() != p.geo_version) { // map() returns a pointer to the GL buffer UT_Vector3F *pdata = static_cast<UT_Vector3F *>(pos->map®); if(pdata) { for(int t=0; t<num_tets; t++) { pdata[0] = pt(t*4); pdata[1] = pt(t*4+1); pdata[2] = pt(t*4+2); pdata[3] = pt(t*4); pdata[4] = pt(t*4+2); pdata[5] = pt(t*4+3); pdata[6] = pt(t*4+1); pdata[7] = pt(t*4+2); pdata[8] = pt(t*4+3); pdata[9] = pt(t*4); pdata[10] = pt(t*4+3); pdata[11] = pt(t*4+1); pdata += 12; } Cheers Quote Link to comment Share on other sites More sharing options...
nicholas_yue Posted December 15, 2014 Author Share Posted December 15, 2014 Answering my own post. The usage of the points to draw geometry is determined in the call myGeo->connectSomePrimsI() There are a variety of options closely related to OpenGL primitives GL_* enums. Cheers Quote Link to comment Share on other sites More sharing options...
