Cloth: Per Object Collision?
galagast
I'm testing a setup where I would want to procedurally assign collision relationships on a per object-to-object basis.
Say I have 2 Cloth Objects (cloth_0 and cloth_1), and I also have 2 Static Objects (box_0 and box_1).
  • I would want the ff partnering:
    box_0 to only affect cloth_0
    box_1 to only affect cloth_1
Currently, it works if I'm assigning it manually using the Collide Relationship DOP.
(The setup below was modified to allow multiple objects to be created per primitive group).
post-3610-0-02792800-1420124898_thumb.jp
post-3610-0-51198100-1420124905_thumb.jp
Later on, I may want to increase the number of partner objects.. Is there a way to go about this procedurally?
I tried using the $OBJID on the Affected/Affector Objects parameter like this:
post-3610-0-95785200-1420124909_thumb.jp
I also have primitive groups named piece_* for each object:
  • cloth_0 and box_0 are on primitive group piece_0.
  • cloth_1 and box_1 are on primitive group piece_1.
But don't know where or how to use the data to assign custom relationships.
I'm also looking into creating an indexing attribute that I could use to assign the partner relationships but haven't had any luck making it work.
I've attached a hipnc file below.
Any help to point me in any direction would be very much appreciated :)
BTW, Happy New Year guys!
cloth.custom_affector.h13.v01.01.hipnc
For now, opdigits seems to help with going the non-procedural way of creating multiple copies of the Collide Relationship DOP..
(Minor question.. Is there a FOR EACH SOP equivalent in DOPs?)
Edited by galagast
  • 3 weeks later...
 the apply relationship dop is similar to a foreach node in sops:  https://www.sidefx.com/docs/houdini13.0/nodes/dop/applyrel
 -G
