pyro shader and volume basic question
harima
Hi All.
I have set up a very easy scene to get my head around the pyro shader and I already have an issue.
Setup is just a 2D volume with size 10 on x axis with density mapped from 0 to 10 across x .
In Geometry node test1 I am doing all the density remap inside the volumevop and everything works as I expect.
(fit density to go from 0-10 to 0-1 and then reshape with a spline ramp to give a hill shape)
In Geometry node test2 I am trying to do the same through the pyro shader but the result is not the same. So I guess I am missing something .
Please when you have some free time have a look in my hip file.
Thank you.
pyrodensityremaptest.hipnc
  • 2 weeks later...
Hi guys,
Sorry to bring this up again but it really bugs me :)
Has anyone got the chance to check this issue?
Btw it doesn't have to be a pyro shader. Basically if I try to reshape the density at render time by using the fit and the ramp from SOPS  it doesn't behave the same.
Really wondering if thats a limitation or I have a fundamental misunderstanding regarding volumes and rendering .
Cheers!
