volume procedural octree divisions and lost details
mrWolf
hi all volume procedural lovers,
I have a volume procedural shader that generates clouds from points. I was thinking to use this to create a large cloud distribution at render time (I've a 'twin' variant of the same shader that creates the same volume in sop using bounding boxes to inspect specific areas of the distribution, so I can preview the result quickly).
I realized that when the point distribution I use as an input becomes very large, in my renders I loose all the details. I tried to crank up the parameter "octree division" up to values that make the pre-processing stage immensely long, and still I am very far from the details I have if I use a way way smaller point distribution.
My question is:
since the volume procedural shader is able to render "gridless" volumes, this should allow rendering pretty much infinite volume distribution. Or ... to be more precise, this is what I (naively) thought !
Is there something crucial I am missing in my setup, or the only solution is split my data to countless small partitions, and pretty much nullify the advantage of the gridless volume render ?
Edited by mrWolf
