Multiparm
Fenolis
Okay, so I've been messing around with the parameter interfaces, and I notice that under the "Folder" parameter there's an option for "Folder Type > Multiparm Block". This looks similar to the Add SOP's interface, where you can create multiple objects(points) and have different settings apply to each object.
I feel that this parameter would be useful in a case where you want to be able to create a number of "objects", each with different settings such as Transform or Scale, or even different objects, but in the same parameter folder.
post-12461-0-21732700-1422513563_thumb.j
This is what I've come up with, as a sort of basic use for the Multiparm Folder Type. My question is, is there a way to default the transformX parameter in such a way that new objects would be placed on the +X side of the existing objects? (Currently I have to manually move each copy to the right location, and that doesn't seem the ideal method.)
Also, I figured out how to stamp copies using the Multiparm parameter..kind of an interesting way of using the $CY expression...
multiparm_test.hipncFetching info...
