Guest xionmark Posted March 28, 2005 Share Posted March 28, 2005 Hey Hok thank You for rerl!I have just tested it. It works great but $string =~ s/\*\/\s/\*\/\*/g; # Replace "*/ " to "*/*" should be replaced with $string =~ s/\*\/\s/\*\/\*/g; # Replace "/* " to "/*!" 14017[/snapback] Hi there, Would you mind reposting the Perl code (h2doxygen.zip) again? I can't find the copy I thought I had saved and I'd like to regenerate the HDK docs again. Thanks! --Mark Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted March 28, 2005 Share Posted March 28, 2005 Never mind ... 5 minutes after I posted this I found it ... Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted April 1, 2005 Share Posted April 1, 2005 I just finished processing the HDK header files again using the Perl code and it does in fact reveal some interesting remarks in the comments. It doesn't handle the standard C type of commenting, i.e. /* .. some comment ... */ which in many cases has a lot on info too. I'll see if I can post these new docs and look into modifying the script for the C style comments later, it also needs a way to read a list of directories instead being prompted (maybe it's already in there ?). I'll see if I can get these posted on the Wiki soon. Thanks for the Perl code! --Mark Quote Link to comment Share on other sites More sharing options...
