Ground shattering problem
jim c
I'm trying to get my surface to shatter along am animated trail. I'm using a sphere animated along a curve to push up the shattered parts, and then a deforming terrain object that "catches" the broken pieces. See 1st attached image.
post-4235-0-27219300-1424534939_thumb.jp
The first 18 frames work perfectly. Then all of a sudden on frame 19, all the other fracture pieces go haywire (see 2nd image).
post-4235-0-71072700-1424534961_thumb.jp
I've attached a simple test of this. Is there something obvious I'm missing?
groundshatter.hipnc
Check grid_object2/make_terrain node. between 18-19 frame you can see that the boundary of the object is slightly different - in combination with concave object probably this is causing instability in simulation .
Right click -> Allow Editing on contents on grid_object2 node.
Dive inside make terrain network, select extrude_volume1 and uncheck Flatten Base option.
Now it will work much better.
Good luck!
Wow, thanks so much, works perfectly now!! I did see the change in the collision boundary, but I didn't understand why it was happening, and since it seems to just go down, I didn't think it was affecting anything. I wonder if I make the terrain a full 3d shape instead of just a plain, if it would behave nicer? Anyways, thanks a lot!
OK one last weird issue. The shattering object seems to elevate a small amount after frame 1, and I'm not sure why. Playing with the terrain object doesn't seem to matter, and it's size doesn't seem to change either, so I don't *think* that's the issue. The shatter object has it's object level TY set to 0.12, but that's NOT key framed. It just seems to jump up a small amount and then hover there. Is that normal? Changing the rbd solver's sub steps doesn't seem to have any affect.
post-4235-0-25461000-1424541021_thumb.jp
