export particles using the realflow format
coclea
I want to export particles or points using the realflow format.
My code is almost working, I am probably just missing a character that makes the file readable, as the realflow plug in reads the file but just display the last particle.
I am using version 9 of the realflow bin format.
Does anyone have an idea what could be missing?
Please find the code below:
    version = 9
    node = hou.pwd()
    geo = node.geometry()
    fileIn = open( fileName, 'wb')
    fileIn.write( struct.pack('H', 0xBADA))
    fileIn.write( struct.pack('H', 0xFA))
    name = "exportParticles"
    name = name.replace( "\n", "")
    print( len(name))
    fileIn.write( struct.pack( '250s', name.ljust( 250 , '\0')))
    fileIn.write( struct.pack('h', version))
    fileIn.write( struct.pack('f', 1.0))        #scale scene
    fileIn.write( struct.pack('l', 5))          #fluid type
    fileIn.write( struct.pack('f', (frame*getFramesPerSecond())))        #ellapsed time
    fileIn.write( struct.pack('l', frame))          #frameNumber
    fileIn.write( struct.pack('l', getFramesPerSecond()))          #frames per second)
    points = geo.points()
    fileIn.write( struct.pack( 'l', len(points)))
    fileIn.write( struct.pack( 'f', 1.0))        #radius
    fileIn.write( struct.pack( '3f', 1., 1., 1.)) #pressure
    fileIn.write( struct.pack( '3f', 1., 1., 1.)) #speed
    fileIn.write( struct.pack( '3f', 1., 1., 1.))         #temperature
    fileIn.write( struct.pack( '3f', 1., 1., 1.))         #emitter position
    fileIn.write( struct.pack( '3f', 1., 1., 1.))         #emitter rotation
    fileIn.write( struct.pack( '3f', 1., 1., 1.))         #emitter scale
    for p in points:
        fileIn.write( struct.pack('f', p.position()[2]))
        fileIn.write( struct.pack('f', p.position()[1]))
        fileIn.write( struct.pack('f', p.position()[0]))
        #velocity
        fileIn.write( struct.pack('3f', 0., 0., 0.))
        #force
        #vorticity
        #normal
        #neighbours
        fileIn.write( struct.pack('l', 0))
        #uvs
        #info
        fileIn.write( struct.pack('h', 0))
        #age
        fileIn.write( struct.pack('f', 10.))
        #isolated
        fileIn.write( struct.pack('f', 0.))
        #viscosity
        #density
        #pres
        #mass
        fileIn.write( struct.pack('f', 1.))
        #temperature
        #id
#additionnal datas
# additionnal datas RF4
    fileIn.write( struct.pack('?', False))
    fileIn.close()
