wrangle point attribute
hello,
I'm trying to store the values of an attribute in a new one.
after creating a vector attribute test in vop with a noise I want to copy it on v@d in wrangle but..
v@d=@test;
just takes the first index of test
v@d=point(0,"test",@ptnum);
i have to use this to get the correct values
but at the same time
v@Ptemp=@P;
works correctly, even with normals and color.
I tried to change the type fo the attributes in wrangle using setattribtypeinfo but it looks like it doesn't makes any difference.
can anyone explain the logic behind this?
attached a simple example file
attribWeird.hip
v@test;
v@d = @test;
OR
v@d = v@test;
All other @ references are cast as float. To manually specify the VEX datatype for an attribute, you must add a character representing the type before the @ sign. For example, to cast the foo attribute as a string, you would use s@foo.
That's the reason for your issues. When that happens, only the X component of a vector is used.
@P on the other hand is internally recognized as a vector. So you don't need the v@P notation. Altho I usually write this anyway.
edit; forgot link :Dhttp://www.sidefx.com/docs/houdini14.0/vex/snippets Check out the Accessing Geometry Attributes section
Edited by Georgie
