MartinuZ Posted March 10, 2015 Share Posted March 10, 2015 hi, I need to increase the speed at which my particles are traveling along the curve. I can do this with the follow scale but I thought you could use the inherit velocity scale for this aswell, however I can't get it to work. I've added velocity on the points of the curve. something else I need to do? version H14.0.233 Quote Link to comment Share on other sites More sharing options...
pbarua Posted March 10, 2015 Share Posted March 10, 2015 Do you have velocity on the curve in the same direction as popcurveforce? If you want to speed up follow then you need to have it in same direction because this parameter transfers velocity from curve to particles. BTW curve velocity always affects particle velocity only sometimes you may have to use large numbers. Quote Link to comment Share on other sites More sharing options...
