IIBit Posted March 12, 2015 Share Posted March 12, 2015 Hello good people of Odfore, I've just started delving into Houdini 14, trying stuff, playing... You know how it goes. I've managed to make a small simulation, based on the color channel and an Attribute Transfer. Nothing fancy, just a rock rolling down a hill. I've attached a popnet to the terrain generate some debris/dust/... based on the color attribute transfer. The problem I'm having is that the popnet generates particles all over the terrain and only the ones that are affected by the Attribute transfer have velocity. Unfortunately I have had no luck finding how I can delete the particles that have no velocity, or how to generate more or less particles, so I can add some copies. So I wonder what if anyone here can find the solution. You probably can, and the solution is probably very simple, but I've just started out so any help would be appreciated. I hope I make sense. I've enclosed the .hipnc-file so you can take a look. Any other pointers you can give me are more than welcome! Thanks! Falling_Rock_Attrib_Create.hipnc Quote Link to comment Share on other sites More sharing options...
pbarua Posted March 12, 2015 Share Posted March 12, 2015 how to generate more or less particles, so I can add some copies You can scatter points based on color by paint SOP and emit particles from those. Quote Link to comment Share on other sites More sharing options...
pbarua Posted March 12, 2015 Share Posted March 12, 2015 Unfortunately I have had no luck finding how I can delete the particles that have no velocity In delete SOP > Set Entity to Points > Delete by Expression > Filter Expression length($VX, $VY, $VZ) == 0 or length($VX, $VY, $VZ) < 0.1 Quote Link to comment Share on other sites More sharing options...
Sierra62 Posted March 12, 2015 Share Posted March 12, 2015 I have modified your file to group the primitives that vel does not equal 0 and then emit particles based on the group. Falling_Rock_Attrib_Create_vel.hipnc Quote Link to comment Share on other sites More sharing options...
pbarua Posted March 12, 2015 Share Posted March 12, 2015 Or in AttribWrangle: if(length(@v) < 0.1) removepoint(geoself(), @ptnum); Quote Link to comment Share on other sites More sharing options...
pbarua Posted March 12, 2015 Share Posted March 12, 2015 Or can use group by expression: length($VX, $VY, $VZ) < 0.1 Quote Link to comment Share on other sites More sharing options...
IIBit Posted March 12, 2015 Author Share Posted March 12, 2015 Wow, thanks a lot everybody! That helps me out a lot. It never ceases to amaze me how flexible Houdini is. I'd better dive in to expression too. Quote Link to comment Share on other sites More sharing options...
rayman Posted March 13, 2015 Share Posted March 13, 2015 Go with wrangles if you have many (millions of) particles - its just much, much faster. Quote Link to comment Share on other sites More sharing options...
mwillustrations Posted February 23, 2018 Share Posted February 23, 2018 Is there a way to this in a DOP network? Quote Link to comment Share on other sites More sharing options...
toadstorm Posted February 23, 2018 Share Posted February 23, 2018 Use a Geometry Wrangle or a POP Wrangle if you're dealing with particles, and use an expression like this: if(len(v@v) < ch("min_speed")) { removepoint(0, @ptnum); } Or use a SOP Solver in your DOP network to delete the points using any of the SOP-based methods listed above. 1 Quote Link to comment Share on other sites More sharing options...
