H13 deeps to nuke8
I am trying to render out deeps to use within nuke, but I can't get them to work properly and I am not sure if I am missing something, as it's the first time I am trying to do this out of the box.
If I render using just 1 render sample (both rayTrace and microPolys) it looks as expected, but if I use any more than that, the deep points spread in Z, resulting in half transparent objects once I try to deepMerge them.
I am writing out .exr files, no DCM Pre-Composite Samples, neither any extra rendering attributes on the mantra node.
any ideas?
(top view is with 1 sample, bottom is with 3)
post-10850-0-65692100-1426198643_thumb.j
I just tried with nuke 8.0v5b28 and also nuke 9.0v4, but I get the same results.
But in theory, should the deeps work straight out of the box between houdini and nuke, using exr?
thank you
