johnLIC Posted March 18, 2015 Share Posted March 18, 2015 (edited) I was working in a .hip file, and I created a mantra node in the "out" context. It has 4 tabs: main, objects, properties, scripts I versioned up the scene file, and the mantra node now has a different layout: Render / Render to MPlay / Render Control... and then below, it has the tabs: images / rendering / objects / scripts / driver What gives? Are some of them mantra IPR nodes? And why are they changing behind my back? Edited March 18, 2015 by johnLIC Quote Link to comment Share on other sites More sharing options...
Georgie Posted March 19, 2015 Share Posted March 19, 2015 (edited) 2 things come to mind : 1. If I'm not mistaken, the layout in H13 is different than the one in H14 -- did you upgrade ? 2. are you sure you didn't drop a Mantra Archive ROP instead of a Mantra ROP ? Edited March 19, 2015 by Georgie Quote Link to comment Share on other sites More sharing options...
johnLIC Posted March 19, 2015 Author Share Posted March 19, 2015 I think there was an install of H13 previously. I might have a Mantra Archive ROP. I will make one and compare. Quote Link to comment Share on other sites More sharing options...
