$HIP/$HIP/renders/... double $HIP bug? help?
I'm using $HIP in paths in Houdini - to output renders, and to point at intial states. It has suddenly stopped working. When I open the file browser, at the top, in red, is the path that is typed in the text field in the main UI, except that the "$HIP..." at the beginning is repalced with "$HIP/$HIP/..."
This is a rel showstopper for me at this point. I need to use $HIP because I'm using HQueue on a network.
Anyone have a work-around?
