constraint clusters together
i am pretty new to houdini, so i am not sure if it´s just a simple problem.
My idea was to create fracture constraints for all cluster pieces which works fine with a for each node ->OUT_CLUSTERPieceConstraint
I thought i could do the same just with the cluster. So i would have control over the cluster constraints and the clusterpieces constraints.
But for some reason i can´t get it work. If you have a look at my attached file you can see that the "connectadjacentpieces4" seems to work under the "OUT_ClusterConstraint" output.
But if you have a look in the dopnet, i can´t see my constraint connections anymore -> constraintnetwork2
I have absolutely no idea what´s wrong with it.
I would be really happy if someone could help me :)
Thank you
herozero
FRACTUREtest.hipnc
