DOP groups for rbd Packed Objects
mrWolf
I have a RBD sim, with 1 packed object which contains 9 elements.
I am trying to disable the gravity only on certain elements, within the packed object.
In order to achieve this, I would like to control the gravity node with a dop group.
I created a point attribute "falling" which I control in a sop solver, within the dop network.
Then I created a DOP Group that creates a group based on the following expression:
point($DOPNET+":"+$OBJID+"/Geometry",$OBJ,"falling",0)
post-1409-0-62246900-1427424243_thumb.pn
Now, this seems to work but ...not quite.
I see elements that start fluctuating at a certain moment, but this moment doesn't match the moment when the "falling" attribute is triggered to 0.
To start, I'd like to understand if I am using the above expression correctly.
I am quite confused with the global variables $OBJID , $OBJ used with Packed Objects.
Could anyone shed some light on this?
I am on H13.0.547
Edited by mrWolf
  On 3/27/2015 at 5:13 AM, Pradeep Barua said:
Check this thread:
POP forces and Bullet sim
hi Pradeep,
thank you for the example hip file, very much appreciated.
Your explanation makes sense and it works great !
I was trying to stay in the rbd land and use the old style way to drive rbd objects.
But I guess with rbd packed primitives , since we deal with points and transformation matrices opposed to real geometry, we are suddenly in a pop world instead !
I've read often here and there that it's possible to access the real geometry of a rbd packed primitive in a sop solver (meaning, unpack ... use and re-pack), but I wasn't able to accomplish this. Meaning that when I re-pack the element it's not the same as the one I unpacked (primintrinsic are lost when unpacking), so the sim breaks.
Is there a proper way to actually extract the packed data , within DOP, use it, and repack it seamlessly ?
