HDW Posted April 5, 2015 Share Posted April 5, 2015 Hi there, I have just started to learn houdini, so, hope you don't mind if the question is too lower level =] I'm doing a little test, trying to simulate throwing an icecream ball onto something.The problem here right now, is after I added a drag force node, all the particles are froze in the air...I only want the particles which collide with the surface to be froze. So, I'm wondering how could I check the per particle's velocity as a condition to apply it on the drag foce? I hope I explained the problem well. The file is attached below. Thanks a lot if any body can give any kinds of suggestions. icecream_test_v03.hipnc Quote Link to comment Share on other sites More sharing options...
HDW Posted April 5, 2015 Author Share Posted April 5, 2015 Hi all, I find some thing from previous post. One is from here: http://forums.odforce.net/topic/22181-deleting-particles-without-velocity-%C2%AB-warning-beginner-question-%C2%BB/?hl=%2Bgroup+%2Bparticles#entry131998 using a group node to separate particles by velocity length($VX, $VY, $VZ) < 0.1 and using a 'pop force' node doing something like this. //groups created in SOPs. if(@group_red == 1) { //set total force to force*0.2 for redGRP force *= 0.2; } if(@group_green == 1) { //set noise amplitude amp+10 for greenGRP amp += 10; } but here is another problem, when I mid-click any node in the dopnetwork ( the flipsolver node, merge node or source volume node), none of them has velocity attribute, even position attribute or id attribute...so how could I bring the velocity inhere??? Thanks a lot~~~ =] Quote Link to comment Share on other sites More sharing options...
HDW Posted April 22, 2015 Author Share Posted April 22, 2015 lol~just find the solution by accident.It's simpler than I thought. the easier way is to use old pop solver, which can create drag force in it.But for houdini 13 and 14, plug a 'pop group' node to the 'Sourcing' input of flip solver,and under the combine tab, fill the group name in the Group bar, select Equals mode, then fill in something like : @viscosity>xxxx.(I use viscosity as test). what confusing me before was the 'Rule' tab, I thought I need to type the vex expression there, something like @viscosity > XXX, but it's not working... Hope I could figure out how to use the 'Rule' things by another accident~ the file is attached below, no fancy stuff, but takes me a lot of time to figure out...=.=||| cheers~ grp_ctrol_drag_force.hipnc Quote Link to comment Share on other sites More sharing options...
