Problem with Bullet Constraint
mrcoolmen
If you display your collisions for the Egg you'll see the real geo that bullet deals with; at the moment it looks bad. You could lower the padding for the collision but that doesn't always give better results ; or you could scale up your scene so as not to be forced to lower the padding.
However considering it's not a large scale sim you could get away with using concave to represent the egg and increase the substeps on the bullet solver cause your bullet moves pretty fast. Also play around with the glue strength :)  . I've attached the .hip file
EggYork2.rbd.hip
Edited by radurock
