How to write arnold Procedural can read houdini node
i want to write a arnold Procedural geometry dso which can read houdini node ,
i use sop string path as parm
---------------------code---------------------
static int MyInit(AtNode *mynode, void **user_ptr)
   *user_ptr = mynode; // make a copy of the parent procedural
   soppath = AiNodeGetStr(mynode, "path");
   OP_Node *node;
   SOP_Node *sop;
   node = OPgetDirector()->findNode(soppath);
   //sop->getFullPath(soppath);
std::cout<<soppath<<std::endl;
   G_counter = 0;
   return true;
but when i render with procedural dso
Will pop up error warning:"UT_NetPacket::read: No such file or directory"
