License trouble ( apprentice installation on a machine with no interne
Hello everyone,
I'm installing a version of Houdini 13 on a system without internet. When I try to install the license via the License Administrator, the "install license manually" is greyed out. I also see that the License Administrator can't find "c:\windows\keys\licenses.local". I've tried the command line, but to no avail.
** EDIT **
I've ran the Houdini License Adminstrator as Administrator in Windows ( right click -> runs as adminstrator...) and ran diagnostics and suddenly I could install my licenses manually. Successful install, I might add.
Admins, you may delete this entry, if you wish to do so.
-M
**EDIT 2**
I apologize for the abundant use of the word "Administrator".
Edited by IIBit
it's for the community - there's a 100% chance that someone else will have the same issue, the forums are an incredible resource to search when it is full of information. It's up to you though.   For reference, this is the idea behind the Stack Exchange sites.
