Stalkerx777 Posted April 17, 2015 Share Posted April 17, 2015 Hi. According to houdini documentation on wire object, there are nocollide and externalcollisionallowed attributes which should allow to control collision per-point. However i can't get it to work, please take a look at this scene: wire_nocollide_attributes.hipnc Quote Link to comment Share on other sites More sharing options...
shukin Posted April 17, 2015 Share Posted April 17, 2015 (edited) Hello Alex, Works fine if you switch in Wire Solver Collision Handling to SDF nocollide Edge (vertex) Float You should assign this attribute for two vertexes of the same edge Wires colliding by Edges not by Points externalcollisionallowed Point Integer Will assign Collision attribute on Connected Edges Best Wishes Denys Edited April 17, 2015 by shukin Quote Link to comment Share on other sites More sharing options...
shukin Posted April 17, 2015 Share Posted April 17, 2015 there you go wire_nocollide_attributes_DS.hipnc Quote Link to comment Share on other sites More sharing options...
Stalkerx777 Posted April 17, 2015 Author Share Posted April 17, 2015 Thanks Denys! SDF collision handling is the key! Quote Link to comment Share on other sites More sharing options...
