Delete constraints by force
Pancho
Since I discovered that the magnet force and glue constraints don't work together hand in hand I wondered whether the magnet force can't be used to measure a force on a glue position to decide whether or not this glue constraint should be deleted or not.
I found several approaches here and on other forums using e.g. a sphere to determine the position of a constraint. If it is inside the sphere or object it gets deleted.
Since I am new to H I wonder whether this couldn't be done with a force and a threshold.
Did anybody try anything in this direction?
Cheers
Tom
