tikkle Posted May 21, 2015 Share Posted May 21, 2015 Hey guys! This maybe a stupid question but i can't seem to find the answer. Is there a setting i need to activate to get fur onto an RBD object? When I use the shelf tool "add fur" to an rbd sphere the fur does not appear. Quote Link to comment Share on other sites More sharing options...
Sierra62 Posted May 21, 2015 Share Posted May 21, 2015 Is your RBD object packed? as far as I am aware you cannot put fur onto a packed object. If it is not packed, have you cached it out? or are you trying to simulate it all together? Quote Link to comment Share on other sites More sharing options...
tikkle Posted May 21, 2015 Author Share Posted May 21, 2015 I dont think it's packed, I just created a sphere and pressed the rbd object shelf tool. I tried caching it out and putting fur on the cached sphere but it still isnt working. Quote Link to comment Share on other sites More sharing options...
Sierra62 Posted May 21, 2015 Share Posted May 21, 2015 can you post an example file, it would be easier to help you if I can see your file. Quote Link to comment Share on other sites More sharing options...
tikkle Posted May 21, 2015 Author Share Posted May 21, 2015 Sure http://we.tl/9nV0sjKtXcThanks Quote Link to comment Share on other sites More sharing options...
Sierra62 Posted May 21, 2015 Share Posted May 21, 2015 So I had a quick look at your setup and the problem seems to be that you started with primitive. The fur tools need to be added to a polygon. So you can either change your sphere from primitive to polygon and resim, or you can use a convert node on your cached file. Once I switched it to polygon the fur tools worked just fine. Quote Link to comment Share on other sites More sharing options...
tikkle Posted May 21, 2015 Author Share Posted May 21, 2015 Thank you so much! Quote Link to comment Share on other sites More sharing options...
